pendean
en respuesta a: amandabF6NY3
@amandabF6NY3 wrote:
I can't seem to reliably reproduce this problem.
We may not be able to as well then.
... I'll notice I forgot to toggle a layer or need to add something. When I make the changes in my drawing and publish again, often the new PDF does not capture any of the changes....
Perhaps you forgot to QSAVE that DWG file before publishing again? Or you edited the incorrect DWG file or Layout?
...this issue seems to reset if I restart my computer, and, I can publish from the SSM one time without issue before the problem occurs again. Sometimes I won't see the problem at all on a given day.
That is very odd indeed: does anyone else in your office have these issues with your files and SSM too?
