amandabF6NY3
410 Vistas, 4 Respuestas
Inconsistent Publish to PDF from SSM
Hi, I'm trying to troubleshoot an on-again off-again issue I have when publishing from a sheet set. Sometimes I'll publish something to PDF, and in checking the PDF I'll notice I forgot to toggle a layer or need to add something. When I make the changes in my drawing and publish again, often the new PDF does not capture any of the changes.
I can't seem to reliably reproduce this problem. Usually, the first time I publish from the SSM, everything works fine. It's often subsequent publishing that fails to update. The workaround I've been using is to just launch the publish command outside of the SSM, but since we are usually pushing out a handful of sheets out of many from one file it means I have to manually edit the publish list every single time.
Even more confusing, this issue seems to reset if I restart my computer, and, I can publish from the SSM one time without issue before the problem occurs again. Sometimes I won't see the problem at all on a given day.
