- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Hi @manharshavadlamudi_moonMBGF7
Sorry, you can’t create a point cloud from AutoCAD dwg.
However, if you have a file type in laz, las or e57, common point cloud formats, you can use AutoCAD Recap to convert (export) to rcp or rcs format. The formats known as rcp and rcs are created by Recap and are supported by AutoCAD, e.g. Civil3D, Revit and Infraworks. You can’t ‘open’ formats in las, laz or e57 in AutoCAD without first converting them to rcp/rcs format.
Point clouds are commonly created using photogrammetry or laser scanning and involve specialized software to process the points. There might be billions of points in a point cloud and each point stores data. The program you use to analyze and format the data will determine your workflow.
A program like plain vanilla AutoCad cannot create a point cloud.
Chicagolooper
