vinodkl
en respuesta a: jdborgeson
Hello @jdborgeson
From the snapshot shared I could see that there is another block named "arrow" inside of block editor making it a nested block. Use the command "explode" to explode the block named "arrow" so that it takes the color which your are assigning. I hope that solves your problem :cara_con_una_leve_sonrisa:
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
