06-16-2023
08:04 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
06-16-2023
08:04 AM
Editing block color to 'by layer' but it doesnt change the color
I am trying to make this arrow block change color. When I changed the multileader color, the arrow stays this green color. I assume this is because of something to do with the block. when I go to the block editor and try to set the arrow color to by layer (you can see the layer is red), the arrow refuses to change color.
06-16-2023
08:11 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
06-16-2023
08:11 AM
What is the object color (and more importantly layer) defined for that INSIDE the block? BYBLOCK settings work better more often that not vs just "bylayer" in most circumstances.
06-16-2023
08:42 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
06-16-2023
08:42 AM
Hello @jdborgeson
From the snapshot shared I could see that there is another block named "arrow" inside of block editor making it a nested block. Use the command "explode" to explode the block named "arrow" so that it takes the color which your are assigning. I hope that solves your problem ![]()
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
