- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Color Pannel not appearing when OSNAPCOORD changed to 0
I'm getting a very strange issue when changing OSNAPCOORD to '0' causes the color panel to not appear. It's not off screen, I've tried all the actions for that to no avail. Changing OSNAPCOORD back to 1 or 2 doesn't fix the issue, instead I have to restore Autocad defaults entirely. this is a bit of an issue as being able to zoom to grip points in a viewport is pretty necessary for my job and didn't have this issue on my previous machine.
I'm also getting an issue where going into the color panel, regardless of whether it's appearing or not, causes my cursor to hit 'invisible walls' above, below and to the left. I'm able to go over to my monitor to the right and click out of AutoCAD which fixes the issue, but it's every time.
I'm using a brand new PC that work has provided this week to replace my old one which didn't have any such issues.
- Etiquetas relacionadas:
Color Picker
Cursor problem
osnapcoord
System Variables
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
1. Osnapcoord is for general usage, not for just a temporary usage as you need it.
Set Osnapcoord back to 2 or better to 1
2. If you need to use Osnaps while Zoom, create your own Macro/command which starts the osnap mode (temporary).
A simple sample for Zoom Windows and osnap ENDpoints:
'_.ZOOM;_end;\_end;\
3. I don't understand or can't reproduce your isse.
Are talking about this windows AUTOCAD<&Toolsets dialog (Command: COLOR) ?
It works for me however I start it (by command color, click on color icon in ribbon or layerproperties manager, properties panel and so on).
Which Productversion you are talking about, command: ABOUT
Sebastian
