06-14-2023
06:16 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
06-14-2023
06:16 AM
If you read the website very carefully at the bottom shows what software you need to access the kop files (see attached). Also since the downloaded file has .zip file extension that most likely means it’s a compressed file. To see and decompress all the files it contains double click on the zip file and select all the files and drag them out onto a folder location on your hard drive for direct access using Fusion or Inventor.
