TomBeauford
en respuesta a: dave
I've always added a CTRL+T shortcut key to toggle TILEMODE which will toggle between the current layout and the Model tab. Handy if you have a lot of layouts as it remembers which layout to go back to. The shortcut Key macro is:
^C^C^P(ai_onoff "tilemode") Regen ^P
Name it Tilemode, use "Toggle between Model tab and previous layout." as the Description, and use CTRL+T for the Access Key which is easy to remember for Tilemode and isn't already being used. From version 2017 on there's a right click option on tabs to "Activate Model Tab" or "Activate Previous Layout" and the Model tab is always visible but using Ctrl+T is still much quicker.
64bit AutoCAD Map & Civil 3D 2023
Architecture Engineering & Construction Collection
2023
Windows 10 Dell i7-12850HX 2.1 Ghz 12GB NVIDIA RTX A3000 12GB Graphics Adapter
