pendean
en respuesta a: jdfnnl
@jdfnnl why are you changing if I may ask?
And if I may also ask, TABLESTYLE command (even in R2015) has a tab called BORDERS where you can define the lineweight BYBLOCK or BYLAYER, why not use those to assign whatever you want/need whether in CTB or STB? Same in the TEXT tab is you still us old stick fonts (SHX) instead of TTFs).
Same applies to lines and plines and so much more.
