Kent1Cooper
en respuesta a: sdvannelli
For single-line, try this:
*TILE_12x24, 1/3 running bond, single-line as if with 1/8 joints
0, 0, 0, 0, 12.125
90, 0, 0, 12.125, 8.04166666, 12.125, -24.25
Make sure the file ends with an empty line.
[And by the way, don't use the "Reply to the topic..." slot at the bottom, because things entered there always show as in Reply to Message 1, that is, to yourself in this case.  Use the "REPLY" button toward the lower right in the specific Message you're Replying to, so we can all tell to whom you are Replying.]
ALSO:  I didn't use it for the above, but the RBHPG command [= Running Bond Hatch Pattern Generator] defined in RunningBondHPG.lsp >here< can build that for you.  You would give it the joint-included sizes 24.125 & 12.125 and 1/3 stagger.
Kent Cooper, AIA
