06-01-2023
08:55 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
06-01-2023
08:55 AM
That would really be an 8-1/24 offset.... But are you sure the tiles are true 24x12 actual size? Most things that are to be used with grout/mortar joint width are at nominal sizes, and the actual size is less by the joint width [what are called 8" bricks are really 7-5/8" for a 3/8" mortar joint].
Also, is it your intent that the width of the joints should show in double-line fashion [which will take much than just a "tweak" of the original pattern], or just single-line but reflecting the center-to-center-of-joint size?
Kent Cooper, AIA
