05-30-2023
01:03 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
05-30-2023
01:03 AM
Select all, set thickness to 0
For modelspace and inside all blocks (use BEDIT to edit blocks), for example inside this block with the senseful name SDGSFGDSG or A$C33E27A70 aso.
Whileobjects selected, inside the properties pallet [CTRL]+[1], change the object type to LINE and change THICKNESS to 0,
change object type to ARC and change THICKNESS to 0,
and so on.
Foreach object type
(don't forget you blocks, you can edit the block content by using command BEDIT)
Sebastian
