- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Trim preview keeps freezing my drawings.
I know there is a known issue with 'complex' drawings which can cause trim preview to make the computer lag. However my drawings aren't complicated at all, very simple building floor plans xref'd into my drawing and then i place blocks and simple polylines (straight lines or boxes, nothing with huge amounts of vertices') and not only will it lag, it will completely freeze and lock up with no hope of recovery without killing the process...this is getting very old very quickly...very sick of having to redo 10's of minutes of work at least once a day, simply because the trim command kills the application.
the latest freeze was caused by trimming a straight line with 3 vertices (2 end, one middle) across a spline with 10 vertices spaced out by several meters, the straight line was very much between 2 vertices, so its not an ambiguity thing.
the fix shouldn't be turn off functions this multi-thousand-dollar-a-year application comes built with, if it doesn't work, it should have never been added to the application to begin with.
any replies claiming this is as the solution will not be accepted, so don't bother.
my computer is brand new, 11th gen i7, a 12gb enterprise level graphics card with 32gb of ram on a single stick so its definitely not a fault with the computer.
