LPortner_HLDEQ7YVGYSF
352 Vistas, 2 Respuestas
AutoCad Chamfer without pressing shift button in between
I used to be able to do a Chamfer without pressing the shift button in between. Is there some kind of setting/ lock that got turned on accidentally ? If someone knows the answer, please share
cadffm
en respuesta a: LPortner_HLDEQ7YVGYSF
Start the command, press [F2], what is commands name?
Chamfer (without shift) should use your chamfer dist settings,
while holding shift, it ignores your distance setting and is using dist=0
https://help.autodesk.com/view/ACD/2024/ENU/?guid=GUID-06517FCA-E63D-4E59-A9D9-196C86A3C00D
Sebastian
In command line, Type 'TRIMMODE', and change value to '1', for some reason, this then allows chamfer to work as a shortcut for joining lines
