05-20-2023
04:04 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
05-20-2023
04:04 AM
How are you making the octagons? The wrong result sounds like the octagons have had their corners Chamfered, at a tiny chamfer distance if it's not visually apparent. When the result with triangular faces happens, check whether the Polyline "octagon" really has only 8 vertices.
Also, are your "8 rectangular faces" when it goes wrong really rectangular? When I try the situation I described, between the "triangular" faces [which are really trapezoidal with a near-zero bottom width] are faces that are not rectangular, but trapezoidal, only at less taper than your intended result:
Kent Cooper, AIA
