05-19-2023
06:15 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
05-19-2023
06:15 AM
@chuck.bardsley, you simply need to download it once, add it to the startup suite, and you're good to go. Have everyone in the organization add it to their startup suite or create a macro that does so. You don't need to download it every year. I have lisp routines that I've had since the 90's. So long as the native commands in the lisp routine still work then the lisp routine itself will still work. Otherwise, there is no native command for this. This is why someone wrote the lisp routine in the first place. You can either go to the AUGI wish list site (https://www.augi.com/wish-list) or the Start tab within AutoCAD and request it as a future command. If it gets enough votes then Autodesk considers it. Here it is in the start tab:
