pendean
en respuesta a: Adam-APG
Q: did you try running REGENALL command to see if your draworder issue fixes itself after the STRETCH?
You probably want to ensure HPDRAWORDER variable is always set that way you expect hatches to perform too, and don't be shy about using DRAWODER command too if necessary.
