Adam-APG
1091 Vistas, 12 Respuestas
Stretching objects over a solid hatch causes the objects to disappear behind the hatch
This is a weird issue that I haven't seen until I updated to AutoCAD 2024. I'll attach a picture to show an example of what I'm working with. In the picture you can see my grey solid hatch as well as my magenta detail cuts. I need to stretch the bottom of my frame up, but when I do the detail tags get lost behind the solid hatch so I can't see where they are going. If I wanted to just stretch my detail tag by eye, I couldn't since it disappears from view.
The thing that makes this even weirder is that the issue only happens if the object I'm stretching is already over the solid hatch. So my detail tags that hang outside the hatch area can be stretched over the solid hatch and remain visible.
I've looked through the options to see if there's a setting I'm not finding, but nothing jumps out at me and searching this issue online has come up with nothing.
