cadffm
en respuesta a: jdfnnl
>>"What are these commands known as and is there a complete list?"
Not documented, because it is depenend on the command you are running AND the command you trying to run transparently.
>>"could there be a way of running QSELECT while using other commands?"
No,
but you can use 'ssx (Expresstools) or 'filter - if it works for your specific situation.
>>"An example would be to select all the yellow polylines when running the HATCH command."
Use other selection-tools, or use QSelect first and start hatch command & use  object selectionmethod P(revious)
Sebastian
