- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Importing old lisp routines to 2024
i have several old lisp routines, including menu files, that worked in 2014 but will not import into ACAD 2024. Is there a fix for this?
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Can you please try again, start with:
1) how did you try to import anything from 2014 to 2024?
2) are both 2014 and 2024 running just fine on the same exact computer?
3) do your LISP routines\
a) require a 3rd party add-on to work?
b) Or are they using commands that have been dropped or changed?
c) Or are you just not able to run them at all because you are unsure how LISP files work in AutoCAD?
Let us know.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
I am going to reply to this to say that I too cannot use my lisp routines inside of ADT 2024. I do know how they work. I read through the code and I do not see a place where it is looking "for an old machine". The answers from every direction are what is very vague. It is frustrating in that all of the routines I have use during the past 25 years, Autodesk only picked up changing spaces and text to multiline text. I am positive I am not the only person who used viewport outline or scale multiple around object or rotate in place. Every software developer seems to think they always make things better by changing programs. None of them read customer comments.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
What lisp routine that doesn't work?
Does Autodesk still put out Architectural Desktop in 2024?
Did you install Express Tools?
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
"The answers from every direction are what is very vague"
Sure, if we don't know the source code.
There is one way we don't need the source code (to point exactly to the problem):
Learn the same as the people who can help, to help yourself.
Also: You have the VLIDE to debug your code, this way it is easy to find the problem.
Often the problem is, people using (command statements to controle native commands, instead to program her own function by API.
Commands changes, from tim to time and the (command statement is wrong then.
2014 is very old, command-s instead command is a problem in many codes and it is a thing what Adesk started years before (10years now).
If you need help, share your code and the information of your ABOUT dialog.
Sebastian
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
According to Lee Mac, the routines I have been using were updated between 2015 and 2017. The change space gives me the work around to get the viewport outline in model space so I am content. The others I use only occasionally so I am not worried about it. Maybe I will send a message to Lee Mac about updating for 2024.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
You still doesn't want to say which lisp not working.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
@susan5FAL7 wrote:
...Maybe I will send a message to Lee Mac about updating for 2024.
Always a good move.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
You can look through your old acad.pgp and make your new 2024 acad.pgp the same
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
the old 2014 version.
