- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Based on the information provided, it seems that the issue you're facing with the text on the face of the object could be related to the way the text is displayed or the layer settings. Here are a few possibilities to consider:
1. Text Display Settings: Check the settings of the text object on the face of the object. It's possible that the text is set to display as an outline or has a specific text style applied that is causing the blotchy appearance. Ensure that the text is set to display as a solid, filled font.
2. Layer Settings: Verify the layer settings for the text on the face of the object. Make sure that the layer is set to plot correctly and that it doesn't have any conflicting properties or settings that may affect the appearance when plotted. Check if the layer has any transparency or other effects applied that could cause the blotchy appearance.
3. Plotting Configuration: Review your plotting settings and configuration to ensure that the text on the face of the object is being plotted correctly. Double-check the plot styles, pen assignments, and other related settings to ensure they are not causing any issues.
4. Graphics Card or Printer Drivers: Sometimes, display or printing issues can be related to graphics card or printer drivers. Ensure that your drivers are up to date to avoid any compatibility issues that may affect the appearance of the plotted output.
It may be helpful to experiment with different settings and configurations to isolate the cause of the issue. If none of the above suggestions resolve the problem, you may consider reaching out to the software or CAD support team for further assistance.
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly.
