dmfrazier
en respuesta a: BryanTB7PR
"Would this be a text issue, or layer issue?"
I'm not certain, but this is probably a display (graphics, driver) issue which causes a printer issue.
The problem (maybe obviously) is that the dimensions/text coincide in model space with the 3D model surface, so AutoCAD has some trouble "deciding" which objects should get priority.
First, check to make sure all your drivers are up to date.
You can move the dimension/text objects away from the surfaces by a small amount and the display should improve and the printing issue should go away. (But this will break the associativity, which you might not want to lose.)
You can also resolve this by dimensioning views of the model in paper space.
