BryanTB7PR
881 Vistas, 9 Respuestas
Text over object issue.
Good Morning,  Somewhat new to AutoCad.   I have created a 3d Object, and split in half for adding dimensions.
I have text on the face of the object, and some text off to the side.   The text on the face displays as an outline on the drawing, and the text on the outside is solid. When plotted to PDF or printer the text on the face of the object becomes blotchy and removes some of my dimensioning lines.  The text and lines on the outside of the object plot fine.  Would this be a text issue, or layer issue?
BryanTB7PR
en respuesta a: BryanTB7PR
See Below Screenshots.  Top two are from the plotted version.  I have tried to change the draw order and send my object to back and pull text to front.
dmfrazier
"Would this be a text issue, or layer issue?"
I'm not certain, but this is probably a display (graphics, driver) issue which causes a printer issue.
The problem (maybe obviously) is that the dimensions/text coincide in model space with the 3D model surface, so AutoCAD has some trouble "deciding" which objects should get priority.
First, check to make sure all your drivers are up to date.
You can move the dimension/text objects away from the surfaces by a small amount and the display should improve and the printing issue should go away. (But this will break the associativity, which you might not want to lose.)
You can also resolve this by dimensioning views of the model in paper space.
paullimapa
Perhaps you can share a sample dwg?
Do a screen shot of your Plot window showing plot settings?
Also do a screenshot of your About window showing AutoCAD version
Paul Li
IT Specialist
@The Office
BryanTB7PR
en respuesta a: paullimapa
See attached DWG file, and below screenshot for plot settings.
pendean
TTF fonts do that when you do this
See the first link in my previous reply.
paullimapa
What I would do is goto Layout and inside the mspace vport select all the dimensions & text and execute CHSPACE command bringing those objects into Layout.
Then when you plot, you'll get the shading of the 3d model but with the Dimensions & Textlooking normal (see attached).
Paul Li
IT Specialist
@The Office
jayhar
Based on the information provided, it seems that the issue you're facing with the text on the face of the object could be related to the way the text is displayed or the layer settings. Here are a few possibilities to consider:
1. Text Display Settings: Check the settings of the text object on the face of the object. It's possible that the text is set to display as an outline or has a specific text style applied that is causing the blotchy appearance. Ensure that the text is set to display as a solid, filled font.
2. Layer Settings: Verify the layer settings for the text on the face of the object. Make sure that the layer is set to plot correctly and that it doesn't have any conflicting properties or settings that may affect the appearance when plotted. Check if the layer has any transparency or other effects applied that could cause the blotchy appearance.
3. Plotting Configuration: Review your plotting settings and configuration to ensure that the text on the face of the object is being plotted correctly. Double-check the plot styles, pen assignments, and other related settings to ensure they are not causing any issues.
4. Graphics Card or Printer Drivers: Sometimes, display or printing issues can be related to graphics card or printer drivers. Ensure that your drivers are up to date to avoid any compatibility issues that may affect the appearance of the plotted output.
It may be helpful to experiment with different settings and configurations to isolate the cause of the issue. If none of the above suggestions resolve the problem, you may consider reaching out to the software or CAD support team for further assistance.
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly.
jayhar
en respuesta a: jayhar
If the previous suggestions did not resolve the issue, here are a few more possibilities to consider:
1. Text Formatting: Check the formatting of the text on the face of the object. Ensure that the font size, style, and other formatting options are appropriate for plotting. Sometimes, using complex or non-standard fonts can cause issues when printing or plotting. Try using a different font or simplifying the formatting to see if it improves the plotting quality.
2. Object Properties: Verify the properties of the object itself. Some 3D modeling software allows you to set different rendering or display properties for different parts of an object. Make sure that the face with the text has the correct properties applied, such as solid fill or the appropriate surface style, to ensure it plots correctly.
3. PDF Export Settings: If you're exporting to PDF, check the export settings to ensure they are optimized for printing. Some PDF export options may affect the quality of text or lines. Try adjusting the settings, such as resolution or compression, to see if it improves the appearance when plotted.
4. Graphics or Display Settings: Review your graphics or display settings within your 3D modeling software. Sometimes, certain settings related to anti-aliasing, shading, or rendering modes can affect the appearance of text or lines when plotted. Experiment with different settings to see if it resolves the issue.
5. Software or Version Compatibility: Ensure that your 3D modeling software and any associated plugins or extensions are up to date. Sometimes, compatibility issues can arise when using outdated software versions or when exporting to specific file formats. Updating your software to the latest version may resolve any known issues.
If none of these suggestions help, it might be beneficial to provide more specific details about the software you are using, the steps you have taken so far, and any screenshots or examples of the issue. With more information, it would be easier to identify the cause of the problem and provide a more targeted solution.
