- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Thanks. Glad I could help. BTW, Just invoking the matchprop command won't take you to that dialog and many would be unfamiliar with it. In addition, even though the checkmarks are generally applicable, most of them won't actually apply anyway. For example, you would need to select a dimension and then settings. If you selected a line, then the dimension checkmark would be irrelevant.
Changing the settings isn't necessarily a good idea either because those settings are sticky. So they could be easily forgotten the next time matchprop is used.
For dimensions, I usually use the properties palette to select the dimension style. I also have a command alias for updating dimension to the current style. (defunc c:up()(command "dim1" "up")). The type-in for that is now "dimstyle apply"
