Kent1Cooper
en respuesta a: jdfnnl
You can change the linetype scale, but that will also change the size of the X's.  If you want those the same, but just spaced differently, change the .5, which [being a positive number] is the pen-down part of the line.  Leave the negative numbers and the text-inclusion part alone, and the text will still fall in the same size gap -- only the length of the line pieces between text inclusions will change.
Kent Cooper, AIA
