jdfnnl
1133 Vistas, 8 Respuestas
modify line type
what is the easiest way to lengthen the distance between fence posts as shown by this linetype?
it is actually not in the acad.lin file, but I think it would read like this:
*FENCE,fence ---- X ---- X ---- X ----
A,.5,-.2,["X",STANDARD,S=.1,U=0.0,X=-0.1,Y=-.05],-.1
Kent1Cooper
en respuesta a: jdfnnl
You can change the linetype scale, but that will also change the size of the X's.  If you want those the same, but just spaced differently, change the .5, which [being a positive number] is the pen-down part of the line.  Leave the negative numbers and the text-inclusion part alone, and the text will still fall in the same size gap -- only the length of the line pieces between text inclusions will change.
Kent Cooper, AIA
jdfnnl
what is the 'U' transform option?
in this article, it is defined as "U= specifies upright or easy-to-read text"
do the numbers that define lengths / offsets correspond to the drawing units?
Kent1Cooper
>Help< will tell you all about it.
Kent Cooper, AIA
pendean
@jdfnnl FWIW if you need an exact and precise spacing of the "posts" that is measurable, then you probably need to be using a DYNAMIC block if ARRAY on a line with a linetype is not an option. Not a linetype.
HTH
jdfnnl
this does seem like a less 'antiquated' method..
here is a link to my dynamic block inquiry
jdfnnl
is it possible to define a linetype that with the text element on both ends?
pendean
@jdfnnl AutoCAD linetypes have to start/end with a dash.
Valentin-WSP
@jdfnnl ,
Read the attached PDF:  Linesanity_ A Journey from Simple to Complex Linetypes.pdf
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
Emilio Valentin
