- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Some of DGN files are error, how to fix it?
I'm currently having issues inserting DGN files into AutoCAD. Some of DGN files are error, how to fix it?
Thanks & Regards,
JAYHAR.M.J
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
@jayhar ,
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
Emilio Valentin
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Looks like you'll have to go back to whoever gave you those corrupt dgn files and request for good ones
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hello, How are you?
I check your Link, but corrupt file is DGN not AutoCad.
I attached DGN file also, that file i need to open
Thanks and Regards
Jayhar M J
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
@jayhar wrote
<<....I'm currently having issues inserting DGN files into AutoCAD. Some of DGN files are error, how to fix it?....>>
No, the files don't have errors.
The dgn is MicroStation format, a CAD program by Bentley Systems. It's commonly used in engineering to build and design infrastructure, e.g., highways, rail transportation, water utilities, etc. Better answers will come from the Civil3D forum rather than this one. There are more experienced dgn importers over there.
How are you opening or importing the dgn files? What command? Or what procedure? Can you upload screenshots?
If you can't open the dgn's, then the issue might not be file error. Have you considered it might be usingthewrongprogramineedmorehorsepower error?
What's that big thing in modelspace? Is it a titleblock? Aw c'mon. Really?
Another way, use MAPIMPORT command.
Chicagolooper
