dbroad
en respuesta a: tramber
A 2-step process is also available that might be simpler than using polar coordinates for typical angles.  Use Cal to calculate a distance and assign it to a variable (say d).  Then using polarmode set to your set of angles, start the line command and point in the desired direction. When the green line appears matching your desired direction enter the distance as !d. Note: direct distance entry is disabled when you issue 'cal at the command line, however.
Architect, Registered NC, VA, SC, & GA.
