pienaarc40
483 Vistas, 5 Respuestas
Cal Command angle
I started the line command and gave it a first point. Now I had to calculate the length of the line all at once in different sizes. Example: (50+32+85/3...) etc. This is more a question of workflow as using Inventor this is an easy enough thing to do. I type 'CAL in the command line to define the expression, but I don't know how to specify the angle after the expression calculated the length.
