fatal.error
en respuesta a: payingtoomuch
@payingtoomuch wrote:
...I have no idea how I might use these individual layer states in the host drawing to help with reloading all the changes.... if they are linked or whatever. Also have no idea how I might accomplish creating new layer states that might help me with getting everything updated without having to go back and forth between the xref and the host drawing as described above...
Once you've set all the desired states in the base xref file, jump to the host file's Layer States Manager (type LAYERS on the command line) and double-click the desired layer state. Make sure that "Don't list layer states in Xrefs" is unchecked.
In addition, you can Import/Export .las files between drawings with the selected layer state.
Etiquetas (2)
