payingtoomuch
en respuesta a: payingtoomuch
Ok. So after digging around a little looks like "layer standards" perse is not what I'm after.
Anyone have any insight into a method to approach this?
Only way I can come up with is to have a template file set up with correct layers..... but would need to start a project with the template.
Could possibly have a dwg file that is used only for layers with lines drawn in model space for each layer then just copy paste the layers into the drawing working in. Problem with that is that all the layers that are already in the project redundant to the layers copied in will overwrite the properties of the layers copied in.
Just brainstorming. For some reason I think I want to get layers OUT of my template and have a file that I only keep up with layers in.... then import those layers into whatever file I'm working on.
