- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Understanding the conventions for specifying a relative folder path will help you .. Relative paths are partially specified folder paths that assume the current drive letter or the folder of the host drawing. This is the most flexible option, and enables you to move a set of drawings from your current drive to a different drive that uses the same folder structure.
Look in the root folder of the host drawing's drive |
| path |
From the folder of the host drawing, follow the specified path |
| \path |
From the root folder, follow the specified path |
| .\path |
| ..\path |
From the folder of the host drawing, move up one folder level and follow the specified path |
| ..\..\path |
From the folder of the host drawing, move up two folder levels and follow the specified path |
Imad Habash
