imadHabash
en respuesta a: muzaffarhabibjonov
You have a Minsert blocks .. You can not explode it directly. You may need an outsource lisp or plugins to fix your blocks. For more info follow these links >> Click <<  >> Click1 <<
Note: In some cases you can fix the issue by using ‘FLATTEN’ command then 'EXPLODE' command.But you may get undesirable results.
Good Luck..
Imad Habash
