04-27-2023
03:05 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
04-27-2023
03:05 AM
Hi, I cannot unblock my drawings, it's unitless seems, may be for this reason I cannot select object when I use Explode command, how to explode, please help to fix my file
¡Resuelto! Ir a solución.
04-27-2023
03:29 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
04-27-2023
03:29 AM
If you BEDIT a Block, there's an entry in the Properties palette about whether or not it is Explodable.
Kent Cooper, AIA
04-27-2023
03:39 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
04-27-2023
03:39 AM
Entered BEDIT command, still cannot be exploded even inside of the block, can you please ckeck out the file
04-27-2023
04:18 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
04-27-2023
04:18 AM
You have a Minsert blocks .. You can not explode it directly. You may need an outsource lisp or plugins to fix your blocks. For more info follow these links >> Click << >> Click1 <<
Note: In some cases you can fix the issue by using ‘FLATTEN’ command then 'EXPLODE' command.But you may get undesirable results.
Good Luck..
Imad Habash
04-27-2023
04:40 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
