alex_pricop203
en respuesta a: Anonymous
I was having the same problem and i might have found a loophole:
I attempted reinstalling even years later on some ample project that uses a lot of 3d solids, so thought id open the issue at hand. On autocad 2024 or 2023 it seems to have issues sometimes with historical solids(i got no mere idea what that is its just an error ive read) and it works with applying the material from the properties panel on multiple selected faces rather than selecting the faces and clicking the material in it's primary menu.
I have no clue as to why it works if put like that but it seems like a retainability issue with the materials if they arent set from the properties, as if it would not trigger the property change from Material - By Layer to whatever material you got to that face, and it might intuitively be hand in hand with the load the projects uses and the pc the project is modified on, since ive started having the issue after developing a dj controller soundboard quite far to the extent that im missing only a few materials on faces which until now they have worked perfectly in applying to said faces. Hope this helped even with the older topic and the recurring forum issue i've seen so far.
