AVCPlugins
en respuesta a: leekennewell
There is absolutely no point in editing boxes through the properties panel when there is a universal, fast and convenient way to modify solids by moving faces. Editing dimensions in the properties panel is a fundamental mistake, because you do not control the direction of resizing and the part inside the assembly is shifted randomly. After that, you are forced to use the move command anyway. This is an extra waste of time. It's a completely different matter when you select the desired faces and rearrange them to a point specified by snaps to other parts of the assembly. Then you will not need to correct the position of the part. In addition, the method of moving faces works with all assembly parts at once in one command. I strongly advise everyone to forget that in some (very rare) cases you can change the size of a part in the properties panel. This is a habit from parametric programs and has nothing to do with professional work in AutoCAD.
Plugins for AutoCAD
A>V>C>
AppStore | Facebook | Twitter | YouTube | Blog
