- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
I didn't understand why you weren't satisfied with the ModelDoc views? Create on each sheet the main view of the model (ViewBase command), and then make as many sectional views as you need. Moreover, the main view can even be outside the printed area of the sheet. But it must be on every sheet - otherwise you can't build a section. And, of course, you should use a solid model, not some polygonal garbage.
So AutoCAD is a great program for modeling furniture, exhibition stands, promotional items, lightboxes and much more. Those who say that "AutoCAD is for 2D" simply do not know how to use it and use it off topic. Of course, it is not suitable for designing houses. Architects have their own add-on for AutoCAD and there are 100,500 more BIM programs. There is absolutely no need for builders to use pure AutoCAD. They already receive too much attention from software developers. Terribly unfair.
