paullimapa
en respuesta a: CrazyIvan
bear in mind though autocad can do 3d it's really good at 2d. So there are no built-in commands in vanilla autocad to do what you want. But what I typically do to make it easy is to xref the 3d model into the sheet file where I plan to setup all these views. Then I can xclip the xref where I want the view, rotate the view into elevation and then do it again for the next view.
Paul Li
IT Specialist
@The Office
