lucas_boisson
en respuesta a: ubul3
Well, I managed to make it work by changing the affected shortcuts.
Firstly, I attached it to the arrow keys, then to the 8, 4, 6, 2 keypad numbers. That didn't work, no lines appeared on the command line.
I wanted to try another way, so I affected a new macro to a random shortcut (Ctrl+H), and it kind of worked because the new macro wasn't working well, but the macro we talked about worked just fine.
I think there is maybe some kinda conflict with other shortcuts when using arrow keys or keypad numbers.
Anyway, thank you very much for your help.
