- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Hi All,
I am currently working in a file that has 7 different page layouts, each one having a title block. All 7 pages use the same block so when the attributes are edited it changes the values on all pages. My question is if I want to change the values on say just "page 5" how do i make that title block independent, or edit the values independently with out exploding the title block.
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
how are you editing now?
should be to edit the the attribute by clicking on it ...
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
@cameron_s Use command EATTEDIT (enhanced attribute editor) and set accordingly. This way you don't need to explode to edit a block.
Command BATTMAN will be usefull to manage your enhanced attributes.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Im sorry for my bad description...What i am trying to edit is not an attribute it is part of the title block. I have to use the comand DWGPROPS to edit the field as it is not listed under the attributes that i can change independently.
thanks
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
thanks
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
I cant post the file its sensitive information. I will see if I can put together a better explanation.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
just erase everything in modelspace, all we need to see is paperspace layouts
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Ok so here's the test file.
If i edit attributes it gives me a few options of what fields i can edit. But if i want to change the text under "revision" or the text under "date" i have to use the command "DWGPROPS" to edit those fields. Now when editing these revision fields it changes all the text throughout all paper space layouts. Is there anyway to edit the revision/date text on just one layout page "SD7"
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
those "fields" are just TEXT
redefine your block and change the TEXT to ATTRIBUTES
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Is there any chance you could go into a little more detail about that process.
Appreciate your time
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Sent from my iPhone
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
