04-12-2023
03:22 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
04-12-2023
03:22 AM
First, drag & drop the desired command into the shortcut keys list then select it and add a shortcut key to it. See the attached images.
Note: On Mac you can not add shortcut keys to macros (some kind of system limitation). The only way is to use macros is to create Toolbar buttons. The process is quite similar, create you own toolbar in the CUI and drop the desired command in there.
For Mac users:
