TomBeauford
en respuesta a: a.kouchakzadeh
Follow the instructions in my previous post to quickly add both the acad - Convert.ctb & acad - Convert.stb files that you can use from now on for doing this.
Once you have the drawing set for acad - Convert.stb you can change it to whichever stb file you want.
Of course you will still need to assign Plot Styles to all the layers and / or objects you need them set for.
If you already have a template with all the layers set up with the Plot Styles for the stb you want to use then create a new drawing with it, insert that CTB drawing and copy layouts as needed.
Drawing Standards may help as well.
64bit AutoCAD Map & Civil 3D 2023
Architecture Engineering & Construction Collection
2023
Windows 10 Dell i7-12850HX 2.1 Ghz 12GB NVIDIA RTX A3000 12GB Graphics Adapter
