dany_rochefort
en respuesta a: epolydorou01
@epolydorou01  Here is your drawing to scale 1 : 200 on a 11X17 sheet.  Drawing would look a bit better at 1:150 or 1:120 scale which i have also included.
As for the angles, see annoted image.
important information for you : this drawing has been drafted ''not to scale''. So other that reproducing the drawing for informational reference, you will not be able to measure off of it. I used the 21100mm to scale it up and the other dimensions do not correspond. Your new drawing scale should be NTS (not to scale).
