pendean
en respuesta a: n.fard18ex
@n.fard18ex So in earlier versions, after the VIEWBASE is created in the layout, "move" is activated for placement.
So your issue may simply be your video card in 2024 is failing to display what you drew in modelspace only, otherwise the command continues as designed to create other views like nothing went wrong.
In your ACA2024 set DFXDX12 to zero, restart the program, and see if your graphics card behaves any better.
if that does not help, start GRAPHICSCONFIG command then turn off hardware acceleration then try again.
FWIW it is considered very premature to commit to a brand new AutoCAD year version so early on after release by those of us who've use AutoCAD versions for some time now: I suggest you roll back to ACA2023 then fully update that 2023 version if this problem continues for you in ACA2024.
