dany_rochefort
en respuesta a: epolydorou01
@epolydorou01
-Insert your drawing into autocad
-Put the drawing on a layer and lock it
-Trace over the whole drawing geometry on someother layer (dont trace over dimensions tho)
- Once that is done, use a measurement on your drawing for a scale refrence.
                         Trace a line perfectly over the 2100mm dimension line.
                         Next draw a line that is truly 21100mm long.
                         Then use your traced line and scale reference it up to your real length of 21100mm
- Your drawing is now to scale
- Increase your dimstryle to 1:200
- Now fine tune all of dimesions and dratfting element to match your drawing
- Finally put that on a template with a 1:200 scale
OR
Post your drawing and we'll scale reference it for you...
