g_perron28SSL
205 Vistas, 1 Respuesta
change dim style same view different viewport
Is it possible to change the dimstyle in one viewport without affecting the same view in a different viewport. I have one viewport on a scale of 1/4=1 and the other one is 1/2=1 for a close up, but the dimensions are to big on the close up. can I change the same dimensions but on different style in different viewport?
imadHabash
en respuesta a: g_perron28SSL
Hi and Welcome to AutoCAD Forum,
The answer depends on your exact needs. If you have a size problem for your dimensions then you can modify your dimstyle to be Annotative . >>Click<<
Imad Habash
