pendean
en respuesta a: a.kouchakzadeh
A DWG file is either set to seek out CTB, or STB. Never both. Your file is stuck in CTB mode. Just a basic how-AutoCAD-works thing. Now you know.
if the convert tips do not work for you for whatever reason (we do not access to all of your files to help out), then as you have tested and confirmed, you will need to open a blank template file (one of yours) that is preset to use STBs, then you will need to INSERT or copy/paste the content there, and if needed move those layouts as well (ADCENTER).
