georgeburistor
1513 Vistas, 3 Respuestas
How to disable snap for one specific layer
I am a set design student who is new to Autocad for drafting, I normally create a rough 3D model in 3Dmax then import the dwg to trace different views for faster drafting workflow.
I can't seem to find a way to disable snapping for one specific layer which I imported, as I only use the imported dwg for visual reference. In Vectorworks this can be easily achieved, surely there is a similar function in Autocad?
imadHabash
en respuesta a: georgeburistor
Hi and Welcome to AutoCAD Forum,
It's NOT applicable!!
Imad Habash
RobDraw
I wouldn't be so sure.
Rob
paullimapa
AutoCAD does not provide option to prevent snapping to objects on a layer. But you can use this following method but be careful because there could be complications. Move all objects you don’t want to snap to onto Layer Defpoints and then turn off Layer 0. Now you can still see those objects but cannot select or snap to them as demonstrated here
https://forums.autodesk.com/t5/autocad-forum/cant-select-objects/m-p/11875571#M1102827
Paul Li
IT Specialist
@The Office
