03-31-2023
09:23 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
03-31-2023
09:23 PM
Few things to consider:
1. Properties of objects set to ByLayer - There are a few lisp out there to assign layer properties to the objects on them so they would display and plot the same after being merged to another layer.
2. It would no longer be able to control the display of objects with layers anymore, WYSIWYG!
Easy enough as long as you understand the consequences. I use it often for location maps required on cover sheets for project drawing. Rather than adding a bunch of layers I'll convert those location maps to display required objects with correct linetypes, colors & lineweights but with everything on layer 0.
There are others who convert them to images to insert as it's easier.
64bit AutoCAD Map & Civil 3D 2023
Architecture Engineering & Construction Collection
2023
Windows 10 Dell i7-12850HX 2.1 Ghz 12GB NVIDIA RTX A3000 12GB Graphics Adapter
2023
