- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
@pendeanI have two monitors, and the problem occurs on both. They are both at 3840 x 2160. I don't see the issue on my old computer, even though it has the same resolution monitor and Autocad version, etc.
I have a minimum amount of buttons below on the status bar; there is a significant amount of space between the last layout tab and the first status bar button (see attached).
The real problem is that this setting toggles between the two options, without my changing it. When I drag the top of the Autocad window to "windowed" mode, and then put it back to fullscreen, it toggles from dock above to dock inline. Then when I pan with middle-mouse, it toggles back to dock above. It also does this back-and-forth occasionally while I pan inside a viewport. It's quite jarring, and the behavior is very erratic.
I would like to think this is a bug that should be addressed and fixed, rather than wait for the next revision and hope it showed up on their radar as an issue.
